CRAZY idea but does it have any benefit or merit??
Well doing what I do I was surfing around late last night checking things out and came across something new by steigmeyer and just want to see what some think this may help. Sure they may be lighter but is it going to help at all?? I have to think and hope he has done some dyno but Ill be damed if i can find anything anywhere and he didnt say much in his response to my email other than price which is 500.00 LOL. Discussion and thoughts under new products??? Stiegemeier Porting Services, LLC - Supercharger Rebuild and Repair
It's hard to see products that associate "venom" and "lubricant" and not put those together.... ![Wink](https://www.jaguarforums.com/forum/images/smilies/wink.gif)
If there are no dyno results for products, I think it is safe to assume why.
Dynos are the proof.
Dyno results are easy to obtain.
Therefore if there is no proof, and it would have been easy to obtain...
QUACK
QUACK
Now that would help much more, but would also need serious changes to the casing to get the benefit.
Am not so optimistic about stiegs products, he has already miserably failed his promises for a 75 hp increase on STRs with his snakebite garbage.
And when you look as to what he must be known for (porting a SC), it isn't even worth the money. Have a look here for some of his own used dyno results:
http://www.stiegemeier.com/technical.html
Porting the SC + intake plenum and new plugs yielded only 25 rwhp (4%). Looking at the dyno the plugs may even have played the biggest role. So on our cars, if you would have 350rwhp, 4% would be just 14 rwhp...
Making the rotors lighter would not gain any hp, you only lower the inertia, and as laser says, I would also be wary going this road…
As Avos says it will lower the rotor inertia which can only do something useful if the supercharger belt slips when the engine revs up.
Avos is the SC king but I'd guess if the belt did slip it wouldn't last long.
I believe application of Snake Oil to the belt will prevent slip more effectively than lightening the rotors.
I do have some virgin cold pressed snake oil for sale if anyone needs some.
I just wanted to see the thoughts behind the idea
Although I can't think of any reason why one would wish to preserve one's virginity I am prepared, for a modest extra consideration, to supply virginity retaining virgin cold pressed snake oil for virgin's use only.
This can not only be applied to the devilish Serpentine Belt (look what happened to Adam + Eve) but also rubbed into the Throttle's Body to ensure a 100% WOT-HO.
Needless to say it is an invaluable aid in the Catching of Unicorns.
I'd better stop now or I'll be smacked by a Demi-God (again) Ouch!
Guy-Pierre Boucher
09-16-2015 05:55 PM
