Cruise control not available & now ABS alert followed by performance inhibiter Stype
Old 06-18-2017, 10:08 AM
cgw's Avatar
cgw
cgw is offline
Default Cruise control not available & now ABS alert followed by performance inhibiter Stype
Jaguar suggested i replace battery some months ago to enable cruise control on my 2007 4,2 V8 S-type .
Did not do so until panel alert that performance inhibited - after an ABS alert.
No difference after fitting new battery 3 days ago. After leaving battery terminals disconnected overnight, the PERFORMANCE INHIBITER seems OK but still no cruise control.
STILL HOPING FOR CRUISE CONTROL FIX.
walker.cg@gmail.com
Old 06-18-2017, 12:24 PM
RJ237's Avatar
Received 2,801 Likes on 2,236 Posts
Welcome to the forums. You should probably post on the X200 forum, but I suspect the brake switch could be at fault. It probably has two microswitches like the X308: brake light and cruise control.
Please visit the new member area and introduce yourself. Link:
https://www.jaguarforums.com/forum/n...-intro-must-5/
Old 06-19-2017, 11:11 PM
9under1roof's Avatar
Sorry for the hijack, but,
Our brake light microswitch needs replaced, we believe, on our 98 VDP. Is that the technical term for the part name? I've had a heck of a time googling to buy a replacement.
Old 06-20-2017, 03:37 PM
avern1's Avatar
Received 1,319 Likes on 1,004 Posts
Below is a link to all of the details for replacing the brake switch. The switch is actually 2 micro switches. One for brake and one for cruise. Another thing with the MY XJ8 you have is that the cruise is also controlled by a vacuum canister so check it and the hose also.
https://www.jaguarforums.com/forum/x...g-mode-102828/
philwarner
05-11-2017 05:29 PM
Don B
General Tech Help
11-09-2015 12:59 PM
juggernaut
03-29-2015 02:33 PM
JimC64
03-02-2015 08:07 PM
Quick Reply: Cruise control not available & now ABS alert followed by performance inhibiter Stype
