Daimler 2.5 V8 excessive brake pedal play
I recently replaced my brake fluid reservoir due to a leak. Brakes were then bled but I seem to have excessive play on my brake pedal! Feels like a couple of inches before brakes kick in. Pedal is not spongy, it is loose play! looked in manual which indicates that there is no adjustment available on pedal itself and it has been suggested that master cylinder may be at fault and internal piston not fully returning. Does this sound like a possible cause? I don't want to go to the expense of having it changed if doesn't resolve the problem!
I've read other posts similar, and in case you hadn't, one of the suggestions was to ensure a proper bleed was to remove the caliper itself from the rotor, and make sure the bleed screw is facing directly upwards when you bleed it. Not sure if you had done it, but it might be worth a shot.
dgram
09-08-2018 08:35 AM
Griff79
08-24-2018 07:08 PM
