Daimler V8 Barn Find!!
Old 02-09-2020, 02:40 AM
Bumble7755's Avatar
Morning All,
Just thought I would post the latest photos I had from the Daimler. I tried gaining access to the bottom of the fuel tank, but had to stop. Thinking I may have to revive the whole rear axle but the state of it currently.
Old 02-09-2020, 01:47 PM
Carnival Kid's Avatar
Received 1,010 Likes on 613 Posts
That's some pretty serious looking corrosion, I wonder how it will affect an M.O.T.?
Old 02-09-2020, 02:21 PM
Bumble7755's Avatar
Thinking of stripping this all down and having a proper clean and all. Hopefully it's just surface corrosion.
When I looked at the driveshaft, seemed pretty clean so fairly hopeful it won't be a PITA!
I know the brakes needed complete overhaul so will start there and work my way to the rear diff
Old 02-09-2020, 04:33 PM
Highhorse's Avatar
Received 1,803 Likes on 1,322 Posts
If anyone has wondered why you need to look under a vehicle that has sat in the weeds before...that is why. I had a 67 Mustang that sat in the field before I got it. I went over a railroad track woopty and it broke just behind the subframe and the driveshaft made a nasty howling noise rubbing on the trans tunnel. A teenage lesson learned.
I would heavily recommend reviewing this regarding the driveshaft... https://www.jaguarforums.com/forum/x...g-info-188400/
In accord with the last, this one pertains also regarding the Jurid couplings... https://www.jaguarforums.com/forum/x...pshaft-207717/
Carnival Kid (02-09-2020)
Old 04-28-2020, 05:25 AM
Bumble7755's Avatar
Good Morning All,
I hope you are all keeping safe and well!
Due to the current lockdown, all work on the Daimler has come to a halt. I'm hoping that once the lockdown has been lifted, I can start work on it again. As you have seen from some of the photos, the corrosion under the car is quite horrendous. Together with me having to replace the fuel pump, I'm seriously considering removing the entire rear axle assembly, as 1.) it will give access to the PITA fuel pipes, and 2.) will give me an opportunity to strip the rear axle and clear all the corrosion and replace bushes.
Is the wise??????
Will be looking forward to getting my hands dirty!!
Old 04-28-2020, 06:36 AM
owas's Avatar
Originally Posted by Bumble7755
Good Morning All,
Is the wise??????
Can be cleaned up but honestly, expect to do some welding under there...
The following 2 users liked this post by owas:
A.J.P (04-28-2020), Bumble7755 (04-29-2020)
Old 04-28-2020, 07:57 AM
A.J.P's Avatar
Smile
Hi Bumble7755,
Have just stumbled across your thread,what a good find but quite a bit of work to do there I would imagine.
But a good project if you can do the majority of the work yourself.
On removing the rear axle I would give everything a good spray with penetrating fluid a few days before you start(might help some).
When I removed mine to refurbish it I managed to do it on my own with the help of three trolly jacks and then put it on a "dolly".
The whole unit is quite heavy so using a "dolly" made it easier to move around.
You have to get the rear quite high for it to slide out and If I remember correctly it came out a bit sideways(if that makes sense).
I did a little write up about it for the J.E.C.which will give you a bit of an idea of whats involved.Here's a link:
https://jec.org.uk/forums/viewtopic.php?f=95&t=11902
On the plus side most parts for these cars are readily available either new or second hand.
There always seems to be a good supply of cars breaking for parts,mainly due to rust issues I think.
Did you find out why it was left there in the first place?
Good luck with your project and I look forward to the updates.
Any questions just ask away
Take care and stay safe.
Andy
Bumble7755 (04-28-2020)
  #28
Old 04-28-2020, 11:06 AM
Bumble7755's Avatar
Originally Posted by A.J.P
Hi Bumble7755,
Andy
Hi Andy,
The car was previously owned by my father-in-law, who had left it outside for the past 7 years. Before that, it was a hotel are and was kept immaculate and regularly serviced (still got all the stamps and receipts). My father-in-law has just reached the point where he just gave up with the plans to get it back up and running and was going to scrap it, hence I took it off his hands (although its still parked in his garden).
My plan is to try and do the majority of this myself, with the advice on these forums and some basic tooling. Once I have removed the rear axle, I will post some photos to try and gauge from you guys the extent of the job I will have.
Looking forward to one day being able to take this for a drive.
A.J.P (04-29-2020)
Old 04-28-2020, 06:44 PM
Addicted2boost's Avatar
Received 1,101 Likes on 845 Posts
How many kilometers are on it? If the transmission seems to work good once you get it running and moved, I’d highly recommend installing an updated main pressure regulator valve in the valve body of the transmission. Also, if you didn’t know, do the secondary timing chain tensioners before it’s too late. Good luck with the rust repair.
The following 2 users liked this post by Addicted2boost:
A.J.P (04-29-2020), Bumble7755 (04-29-2020)
  #30
Old 04-28-2020, 07:02 PM
John P's Avatar
After such a long time off the road it still looks a proud car.
Good luck with getting it back on the road, you will love it.
The following 3 users liked this post by John P:
A.J.P (04-29-2020), Bumble7755 (04-29-2020), ericjansen (04-28-2020)
  #31
Old 05-31-2020, 03:00 AM
Bumble7755's Avatar
Morning All,
So I have made progress, the rear axle has been dropped and the fuel tank is out, just waiting for the new pump!
The following 2 users liked this post by Bumble7755:
A.J.P (05-31-2020), Carnival Kid (05-31-2020)
  #32
Old 07-05-2020, 10:21 AM
Bumble7755's Avatar
Afternoon All,
Today is a happy update, I finally have got the car started!!!!!!
In the end, I replaced to entire fuel tank, as the old one was just too brown inside. I say I got it started, it's leaking quite badly, LOL. When attempting to replace the fuel filter, I sheared the fuel feed line to the engine. So in the meantime, I have bypassed the filter with some garden hose, not ideal!
Was just after some suggestions for you guys as the best way to replace the lines.
Cheers!
  #33
Old 07-05-2020, 03:45 PM
Highhorse's Avatar
A pic and better description of "sheared" and where would be helpful. You didn't damage the tank connection did you?
  #34
Old 07-05-2020, 04:11 PM
Bumble7755's Avatar
Hi,
I sheared it immediately after the nut coming off the fuel filter, it had nearly corroded away! So just got some hose to connect the two ends without the filter to get the engine turned over.
No damaged to the tank connector 😁
  #35
Old 07-05-2020, 10:14 PM
Highhorse's Avatar
Ok, I was going to suggest a compression fitting, but with that corrosion the only real option is to replace it. Whether you find a good one at a recycle yard (not a preferred choice), a new one would be best. As a matter of perspective, if one part is corroded that badly, the rest is most assuredly the same. So a complete new fuel line would be the recommended course. But you could find a descent one in the yard possibly. But I'd check on price 1st (for both old and new) to see how it balances.
mtfife
05-24-2024 08:35 AM
97XJR-Flausa
11-27-2016 10:50 PM
mattammba
03-04-2014 01:00 AM
AlfaVeloce
04-04-2013 08:04 PM
teamswooop16
11-29-2009 07:38 PM
Quick Reply: Daimler V8 Barn Find!!
