In Dallas Area and want to make serious $$
Old 01-15-2018, 09:42 AM
Received 8,305 Likes on 5,011 Posts
ICE= In Car Entertainment
bob
sayitaintso (01-15-2018)
  #42
Old 01-15-2018, 11:41 AM
Michael Brown's Avatar
The ICE fuse that controls the radio is a 5 amp fuse located on the passenger side fuse bay located under the back seat. I forget the exact number but it’s location should be marked on the cover or found on line. In my case, the fuse was blown. I also had a strange issue with this fuse related to cold temperature.
I noriced the radio would be dead until the cars cabin had warmed up. I’ve not looked at it in detail yet but I’m assuming that the cold has made the contacts contract
  #43
Old 01-15-2018, 12:06 PM
sayitaintso's Avatar
Thanks for the quick response, will be back at it with the Cat shortly. About 15 degrees out today if I'm lucky. Anything to get this car where I want it!
  #44
Old 01-15-2018, 02:53 PM
Checked and found fuse blown. Changed fuse,radio still wont come on or display message. Keeping the heating issue in mind you referenced, Im going to wait until I warm the cabin up. Thanks Everyone!!
  #45
Old 01-15-2018, 02:59 PM
Fuses are blown for a reason.... after you changed out the fuse and tried unsuccessfully to turn on the head unit, did you re-check the fuse to see if it had blown again?
  #46
Old 01-15-2018, 03:13 PM
Yes rechecked all mentioned fuses again, both heelboards and the boot. Even unattached the disc changer.
