In Dallas Area and want to make serious $$
#41
sayitaintso (01-15-2018)
#42
The ICE fuse that controls the radio is a 5 amp fuse located on the passenger side fuse bay located under the back seat. I forget the exact number but it’s location should be marked on the cover or found on line. In my case, the fuse was blown. I also had a strange issue with this fuse related to cold temperature.
I noriced the radio would be dead until the cars cabin had warmed up. I’ve not looked at it in detail yet but I’m assuming that the cold has made the contacts contract
#43
#44
Checked and found fuse blown. Changed fuse,radio still wont come on or display message. Keeping the heating issue in mind you referenced, Im going to wait until I warm the cabin up. Thanks Everyone!!
#45
Fuses are blown for a reason.... after you changed out the fuse and tried unsuccessfully to turn on the head unit, did you re-check the fuse to see if it had blown again?
#46
Yes rechecked all mentioned fuses again, both heelboards and the boot. Even unattached the disc changer.
