Damn oil leak
I've never seen an oil cooler bypass block installed like that. I guess the engine block started out as a SC and then instead of cooler lines, it was fitted with a bypass block. Maybe a few left over SuperCharged engine cylinder block upper oil pan assys were used with the oil cooler bypass?? Use up the old parts??
Remove the center bolt and replace the 'O'rings!!!!!!!
bob
bob
motorcarman (08-19-2018)
Jsedita74
05-30-2011 08:20 AM
sempaipaul
01-09-2008 08:44 AM
