Damn those XJR wheel nut covers falling off!
I seem to lose about 4 of these a year. They just fall off. I've checked all of them and some seem fixed solid while others rattle a little - how are these suppose to stay on? Tapping them gently doesn't seem to secure them any better, some seem to have gunk on the nut which makes me wonder if there should be some type of sealant/adhesive used to keep them on (but not secure them until the end of time).
I get disproportionately cranky with these little things
![Icon Badrazz](https://www.jaguarforums.com/forum/images/smilies/icon_badrazz.gif)
Hi Troy,
Mine all seem to also be loose and rattle, but none have ever come off. I have lost the washer on the inside, but never the sheet metal cap. My understanding is that these caps are swedged on. I don't treat them gently either - the lug nuts all come off with an impact driver and are torqued to the proper setting when re-installed.
I do have a few spares just in case that I picked up at my last visit to the parts yard, but have not had to use them yet. Perhaps the ones you are having trouble with were overly torqued at an earlier time?
Good luck!
Good luck!
Received 1,797 Likes
If you are talking about the 1.25" or 2" ones, XJ8 Series I & II '98-'08 - XJ8 Sedan Series I, 1998-2002 - Wheels - Wheel Nuts ..has them for a very good price on them. I just replaced all of mine about a month ago. I can tell you there's a seller on Ebay who wants $30 for each one.
For the 2", I believe an issue with the caps is the use of a 1" deep socket instead of a deep well to get down onto the secondary nut pattern when using impact guns. Thus all the torque is placed on the tin cap and loosens it.
grandell (01-16-2017)
![Icon Frown](https://www.jaguarforums.com/forum/images/smilies/icon_frown.gif)
I can tell you they are Eurospares, they shipped them in the sealed bags of 10. Here's another one, a little more expensive though...http://www.nextdayauto.com/2003-jagu...3-1624823.html ...I believe the '03 is the same.
