dash clocks going mental!!
Hi all.
in my on going attempts to fix this pain in the *** car I have yet more symptoms, I need to know if they are connected to the existing issues or not.
I have an intermittent fault with the dash clocks. All of a sudden the rev counter and the temp needles will drop to zero, an array of error lights appear, then after 3 seconds it all returns to normal, it can happen ever 20 seconds or not for weeks.....my main issue is with gearbox faults, which can be generated by a whole host of units so im wondering where this fault comes into play
Any insight would be most welcome....
thanks plumbs, could you go a little deeper with where to find the common ground please, ive checked ever obvious groung leads i can find on the car, and quite a few that ive found hidden away too.....
Toybreaker
12-08-2015 02:01 AM
