dash light bulb replacement
i disassembled the passenger switch a couple weeks ago, that one is lit up, dont know about the rears
here is a pic of the passenger window switch the bulb plugs into those two prongs, sorry dont know the bulb size
http://www.flickr.com/photos/undertaker414/8159768587/
here is a pic of the drivers switch as you can see those clear plastic pieces go into each switch and light up the 4 window switches, through two light bulbs, and as you can see mine melted and broke
http://www.flickr.com/photos/undertaker414/8159802414/
http://www.flickr.com/photos/undertaker414/8159767145/
here is a pic of the other side of the switch
http://www.flickr.com/photos/undertaker414/8159765477/
sorry i initially took the pictures of the drivers switch only to see the damage, i tore the switch apart to see why my rear passenger switch lit up yellow rather then light blue like the others, if someone can pitch in the proper bulb size i will most likely do a Full interior LED swap in the future
one word of advice take your time and be super patient, have a beer do whatever it takes to not snap those little tabs
Tony K
03-26-2024 01:53 PM
rudelover2
09-11-2015 08:53 PM
