Dash light go off & headlights blowwhen i rev the engine
Old 07-15-2019 | 11:07 PM
Lady Penelope's Avatar
With M. Stojanovic's source for a brick store vendor I would go with that
https://store.alternatorparts.com/in...regulator.aspx
Notice the part # IN9218
on swapping out mine I found the screw fused to the brush assembly found on their website so ordered one for installation and a replacement screw from the hardware store
https://store.alternatorparts.com/ni...-assembly.aspx
Sleazy (07-16-2019)
Old 07-15-2019 | 11:26 PM
67ECoupe's Avatar
I might do that on a spare alternator, but to have a reliable unit for a dependable vehicle for my family, I would lean towards getting the entire alternator/regulator unit new with the one-year warranty, since they only go for around $200.
I think of it as insurance to protect the other expensive stuff in my car's electrical system, as well as insuring my safely getting home at night.
Sleazy (07-16-2019)
Old 07-16-2019 | 12:21 AM
Sleazy's Avatar
Originally Posted by M. Stojanovic
If the headlight bulbs blew so quickly, you had a serious over-voltage coming from the alternator. This can only be due to a bad voltage regulator not controlling the voltage, i.e. having a short inside it sending full current to the alternator's exciter coil. In this case, the alternator voltage can go up to as high as 20-30 Volts. Do not go for the cheapest Ebay (fake?) regulators but get one from a reputable supplier. I get Denso alternator parts here: https://store.alternatorparts.com/in...regulator.aspx
As for the engine ECU and other modules, hopefully they are not damaged as they usually have in-built over-voltage protection.
Thats what confuses me, the filaments got burned, I tried to put an OBD reader on the car and it goes through 4 check boxes and on the 5th one it gets stuck and I get some can't communicate message. So I hope it didnt fry the ECM or something like that.
Old 07-16-2019 | 01:45 AM
M. Stojanovic's Avatar
If you could still start the engine after the bulbs burnouts, at least the engine ECU is fine. Don't try to start the engine again with the faulty alternator still in. You can test everything with all wires disconnected from the alternator, i.e. run on the battery for a while (after you have charged it, if not full).
Lady Penelope (07-16-2019)
Old 07-16-2019 | 01:48 AM
Notice the part # IN9218...
They also have IN9218HD (heavy Duty) but they don't state what the difference is.
Sleazy (07-16-2019)
Old 07-16-2019 | 06:03 AM
There is a difference in how fast the regulator responds like with heavy beats from your stereo system and not necessarily with change in RPM
In the X300 case a IN221 is the stranded response and the IN435 is the fast response equipped on the car from factory
The HD may be a 120 amp vs. a 90 amp
120 is required on the X300 , I believe it is required on the X308
Sleazy (07-16-2019)
Old 07-16-2019 | 04:19 PM
Sleazy's Avatar
Update:
I took the alternator out of the vehicle and brought it to the rebuilders. They bench tested it, at idle speed they were getting 17 volts when they cranked up the rpm's they were spiking at 29 volts, so it does appear that I found the issue, I hope it didnt blow anything besides my headlamps
  #28
Old 07-16-2019 | 04:35 PM
67ECoupe's Avatar
Update:
Of course it looks like you're going to have to keep your eye on things that might want to fail prematurely from the over-voltage, starting with your car's battery.
99 Jaguar Vanden Plas
Car starts fine and seems to be running fine when I rev the motor at all the dash lights go black and my headlights blow out and become burned out light bulbs. what could be causing this ?
Meantime, the fact that you said your dash lights went black sounds like your car has an over-voltage protector, also known as a high power protection module, that that protects your more delicate and expensive/critical lower-voltage items.
You might check and see.
Sleazy (07-16-2019)
Old 07-16-2019 | 04:57 PM
67ECoupe's Avatar
Also, here is another "brick & mortar" parts source for your car:
https://www.partsgeek.com/models/van...as/jaguar.html
They are in New Jersey and have a toll-free number.
Sleazy (07-16-2019)
  #30
Old 07-16-2019 | 05:03 PM
Sleazy's Avatar
The one thing that concerns me is the OBD reader is unable to communicate
  #31
Old 07-16-2019 | 05:15 PM
67ECoupe's Avatar
Dang!
I would look for a blown fuse and hope for the best.
Sleazy (07-16-2019)
  #32
Old 07-16-2019 | 10:00 PM
There is a fuse that powers the OBD 2 port
Once someone found the pins in the port bent
See page 143 for a 2001 :
http://www.jagrepair.com/images/AutoRepairPhotos/jagxj2001.pdf
# 4 / 5 amp LH heelboard fuse box
# 10 / 5 amp LH heelboard fuse box
Looking up fuse
Sleazy (07-16-2019)
  #33
Old 07-16-2019 | 10:19 PM
Sleazy's Avatar
Looking up fuse
There is power at the OBD plug, as the reader plugs in powers on and goes through 4 check boxes and hangs on the 5th one, then displays a message can not communicate
  #34
Old 07-16-2019 | 10:25 PM
67ECoupe's Avatar
Do you think it could be the reader?
Sleazy (07-16-2019)
  #35
Old 07-16-2019 | 10:27 PM
Sleazy's Avatar
I tested the reader on a different vehicle, my son's Ford, and it communicated without any issue
  #36
Old 07-16-2019 | 10:41 PM
67ECoupe's Avatar
Maybe a pin in the port is messed up?
Sleazy (07-16-2019)
  #37
Old 07-16-2019 | 10:47 PM
Sleazy's Avatar
I guess that is a possibility, I was thinking maybe with the high voltage that the voltage protection was affecting the operation if the electronics and shutting them down or whatever and that was causing the no communication problem. I was hoping anyways. I was planning on checking it after i get the alternator back in there and if it doesnt read again to take it to the auto zone down the road and see if they can get their code reader to communicate. Mostly I am hoping it works once the voltage is correct again.
  #38
Old 07-16-2019 | 10:48 PM
67ECoupe's Avatar
Good luck, let us know how it goes!
Sleazy (07-16-2019)
  #39
Old 07-16-2019 | 10:51 PM
Sleazy's Avatar
I get the alternator back Thursday afternoon so I will be updating shortly after that
  #40
Old 07-17-2019 | 01:30 AM
I was thinking maybe with the high voltage that the voltage protection was affecting the operation if the electronics and shutting them down or whatever and that was causing the no communication problem. I was planning on checking it after i get the alternator back in there...
You can check it without the alternator. Just connect the battery (make sure that the disconnected main cable to the alternator is not touching the ground) and switch the ignition "on" (do not crank). You can watch the main system check on the instrument panel and see if any fault is displayed. Then try the OBD scanner.
Quick Reply: Dash light go off & headlights blowwhen i rev the engine
