Dash lights replacement
Seems my dash lights are failing. From left to right they seem to be burning out. Is there a write up on replacing the dash lights? How difficult is it to get behind the gauges (Speedo, tach etc) to replace the lighting?
Any info is greatly appreciated,
Thanks,
Pat
Thanks,
Pat
RE: Dash lights replacement
Thanks to both of you. Would you please clarify what IPK stands for?? I have been looking through my on-line manual for dash removal, but I can't find a description or illustration depicting the "pack" you mention.
Is there a "best" place to get these bulbs? or is the dealer the place to go.
Thanks for everything
IPK is abbreviation for instrument pack. Look under fascia, major gauge? Probaly fascia removal will see remove ipk and refer to sro **.**.** That should give you what you need. Easy job. The bulbs are twist in holders on back of pack.
Get the bulbs from the dealer. I have to do mine also. If you cannot find, I will take pics as I do mine this weekend and post Saturday evening.
it should have it written on it, mine said Toshiba 14V 3.4W, they're a T3 "wedge" fitting, I've gone LED, fit and forget for the lifetime of the vehicle, you might as well do all 8 in the IPK.
http://www.htl.co.jp/english/p_pro1_t10.html
Tony K
03-26-2024 01:53 PM
FS[SouthEast]: 2005 Jaguar XKR Convertible Supercharged
divingmom
08-25-2015 07:54 PM
