day time running lights
Won't overriding the switch cos problems? I kno typically in cheap through away cars u can just pull fuse/relay! No real issue, but it becomes concerning with the jag when u start with electrical! I installed hids! Up my fuses to 20 ampbut if both ballast don't turn on when starting I have to turn off my car and restart! This throughs me abs and traction failure light until I turn off restart again then both ballast work, and indicator goes out! If it's rather simple to override it, could someone post how? Thanks
I bought those because of this thread, however they look too blue next to the headlamps for me while stock 194s are too yellow.
Also they are always on, are yours?
Anyone with ideas?
Thanks!
Chris
Thank you, I think I didn't explain myself well. .
Once I plugged in the LEDs they stay on regardless if they are switched on( key in or not) albeit very dimly. Once the car is started and I turn the lamps on they get very bright( what I was looking for but too blue). If I plug the normal 194s no issue. It seems the LEDs are finding power but I don't know how and if anyone else has encountered this.
Thanks again!!
Chris
BrentGardner
28
04-26-2024 03:08 AM
xjrjag
10-27-2021 11:48 PM
X_Type_South_Africa
12-09-2015 05:37 PM
Will P
08-27-2015 06:52 PM
