Inertia switch is behind the passenger kick panel . Remove panel and its up beside the firewall. If the switch goes off you'll have other problems. Other lights gearbox light. You probably need a fuel pump. Check fuel pressure
If you think its fuel, if you don't have a fuel test rig, just replace the fuel pump relay, a cheap check. Fuel pump relay replacement is good PM anyway, they work hard and get hot.
