Destoyed my blower. Gen V Eaton on a 2000 XJR. What exactly does it take?
@SeanB and Rlover
Don't get me wrong, as automatics go the XJR has a great one. I'm not completely thrilled with the programming, as it the shifts are a little gawky and it won't bloody well stay in first to redline like I want it to, but the shifts are very positive and it generally shifts like I would anyway. I had planned on doing the blue top mod to help with some of those issues. But I just flat prefer manuals in all situations besides stop and go, and I don't experience stop and go traffic very often at all. I'm kind of a control freak, so I really want a transmission that does what I input all the time, not one that does what I want most of the time. I think the XJR would be an incredible drive with a stick. I really wish there was an easy manual transmission option out there for the AJ8, because it really is a great engine.
I have about 2800 miles on my car since machining the snout to fit the 3# pulley with no problems or cracks
Received 2,194 Likes
Ive done several 3#ers for people without issue. I have the guys at US distributer of Link G4 engine management systems : Performance Tuning : All wheel dyno : Mustang MD 250 : EngineLogics.com machine the snouts when I have the SC off for coolant hose replacements. Also go read the tech section on Kenne Bell's site on a stock Eaton vs Ported and showed performance DROP!
Its a nice profit job for the companies that offer it imo.
Update: Picked up a 20k mile gen 5 off a 2004 XJR, and got it all buttoned back up over the weekend, this time being very certain there are no bolts in it :P
Installation: This is an EASY swap, I highly recommend anyone who was thinking about doing it go ahead and do it. I just used the gasket for an X350 XJR, and used that as a template for where to clearance my intake elbow from my X308. 20 minutes with a Dremel later (couldn't find a way to chuck it up well in my vertical mill), and I had clearance for the bigger bearings. That's all that's required to get it on. The gen 5 does place the inlet elbow a tiny bit higher, so it was a little bit of a pain to get the bolts that mount the elbow to the blower started (as the little hoses from the bypass valve to the IC boxes get slightly compressed), but all it took was a little more time and cursing. But all in all, easy squeezy. I'll do a separate post going into a little more detail about the particulars of the install tonight when I can upload pics.
Driving impressions:
-First of all, the Gen 5 is much quieter than the gen 3. Much less pronounced blower whine. Personally, I don't like this, I like to hear the blower talk. But if you want less whine, this swap should be top of your list.
-Much less high rpm boost fall off with the gen 5. With the stock blower, the car would kind of fall on it's face a little over 5200 rpm. No such issue with the gen 5, it now pulls VERY hard to redline. No boost fall off here.
-My seat of the pants impression is that it has more power in general. I really wanted to do a dyno comparison, but due to my idiocy I didn't get it to the dyno in stock form before feeding it bolts. So all I have is seat of the pants impression, but it definitely feels like it gained some power.
All in all, a VERY worthwhile upgrade IMO, especially if your Gen 3 could do with a rebuild anyway. Spend that $600 on a low mile Gen 5 instead, you won't be sorry.
Many thanks to Avos and XJR-0220 for all the advice!
The following 2 users liked this post by Cabezagrande:
Rlover (08-13-2012),
WaterDragon (08-14-2012)
Thanks for starting a GREAT thread. I learned a great deal..
straight forward job.
Buy the gasket for the inlet to blower for a 4.2 car. Line the blower up with the inlet and mark where the bearings will hit the inlet. Then use a burr bit to clearance.
You will also need to trim the two small hoses for the bypass valve as the Gen V sits up a bit higher.
Getting the 4 blower to elbow bolts started is a pain, as is getting the outlet to intercooler plates lined up.
I was able to do it without any sort of trimming or machining, but I did replace my needle bearings so maybe I pressed the cup covers in slightly deeper than factory. Using the 4.2 gasket it just all went together, I did put some rtv on the gasket on the intake elbow side to minimize the chance of leak paths there around the caps, that's the only modification I remember. Agreed on difficulty with both seating those bypass hoses and getting the 4 elbow bolts started.
#31
You can only use a blower from the 4.0 V8 S/C and 4.2 V8 S/C engines. I believe the last year for the 4.2 V8 S/C was 2010. Anything with a 3.0 V6 S/C and a 5.0 V8 S/C you cannot use as the blower is entirely different than what you can use on your engine. For example, the 3.0/5.0 S/C has the throttle body on the front of the blower and the one you need has the TB mounting on the back of the blower.
#33
Personally I’d go with a 4.0 blower because I like the gear whine, it’s a direct fit and there’s practically no power gain from a 4.2 blower. I’m pretty sure all the 4.2 blowers are identical. The intercoolers are different but, you can’t use those anyways. The 4.2 blower that has the least amount of mileage is the one you should get if you’re set on a 4.2. Change the blower oil before installing.
#34
A2B, I thought the 4.2 Gen V was a Performance Upgrade.?
My 4.0 Gen IV needs to be rebuilt according to a Jag Mech. But I don't know any Jaguar Supercharger Rebuilders in the Northeast or anywhere else in the States. If you know any reputable shops or person in the USA that rebuilds these superchargers, I'd appreciate that info/contact. Otherwise, I believe the next best option would be to source the 4.2.
What say you?
What say you?
#36
#38
- Jon Bond Performance LLC
- highspeed lab
- Stiegemeier Porting Service
you need to plan everything ahead otherwise it is not going to be a fun project.
Good Luck
04 xj8
05-14-2017 08:20 PM
flsupraguy
07-24-2010 05:31 AM
