did timing chains/tensioners. Now have noise
2000 xj8.
so I just did chains and tensioners. No problems with the job. I've done this twice before.
While the car is sitting still it sounds great. Rev to 4k or let it idle, doesn't matter. I let it run long enough to burp the coolant, no issues.
Then I take of down the road and when I gas it I get a banging noise, not rattles like chains loose. When I let off the gas or rev in nuetral it is quiet again.
Car ran perfect before so I am certain this is something I did while I had the front of the motor apart. Could this be VVT? Any ideas?
so I remembered that the right side intake cam was a touch off of level with the exhaust cam so I just unplugged that vvt side. Motor runs great so that sides valve timing is off. I thought I had it set back to the few degrees out that it was when I started, but obviously not. Can I just locate the crank, lock it with the tool, loosen vvt sprocket, set both cams to dead level with the cam tool and a wrench, re-torque the vvt?
The cam timing flats will be slightly off from aligned when the clamping tool is removed. That is because of the pressure of valve springs on the cam lobes. If I remember correctly, they will make a very shallow 'V', only about 2-3 degrees off parallel.
If you did not loosen the intake bolt there is no reason that it needs to adjusted unless obviously out of align per the comments above. Normally, only the exhaust timing needs to be addressed.
Locked down by the flex plate pin, the intake cam flat should be nearly flat with the head machined surfaces.
Did you change the oil during this process? VVT issues usually are associated with oil pressure.
After you started and ran, have you taken off the covers, rotated clockwise to the flats and observed if all four camshafts are in the proper orientation?
I pulled the vvt sprocket because I was doing all 4 chains, tensioners and sprockets. I am going to pull the valve cover tonight and see how "flat" those cam surfaces are. From what you are telling me it would seem that I did not have the intake at full retard when I tightend the sprocket down.
Wolfy
05-28-2024 08:06 AM
innzane
09-02-2015 10:08 AM
