difference between bosch intercooler pump 010 and 002?
the difference is the plug and the liter per min. 010 flows more both are an improvement .
i cut the plastic plug off around the 010 pins , actually cut the pins back to nearly flush about 0.5mm remaining , and soldered the hella cable and plug to it .
then a dollop of urethane over it to strengthen the join . and protect it .
https://www.jaguarforums.com/forum/x...5/#post1475453
Engine Auxiliary Water Pump Mercedes W203 W215 W230 Bosch OEM 0392022010
This is partly what sold me last year (the links in here):
https://mbworld.org/forums/w211-amg/...osch-pump.html
