different bearing sizes ?
I have a 00 xj8 N used a 98 xj8 front wheel hub...the 98 has a different bearing size then the 2000 I put in the 98 and now im throwen an abs code and I changed nothing on the brakes the only thing I changed was hub...would the diff bearing sizea throq the abs code??
how can i clean the sensor without ruining it??? i have mafs cleaner (real Mafs cleaner) would that work??? also i was thinking of switching the sensor from the original hub to the one i put in would that be a fix??? i mean i literally did everything by the book im totally lost on how this happend...fyi i havnt gone 2full weeks in the last 6month without a code or a bearing or a misfire...its getting rediculous the amount of trial and i error i do becuz i dont have all the proper equipment
Collector1
09-26-2015 05:28 PM
XKE73EIconverter
09-26-2015 10:21 AM
