Differential Output Shaft Bearings
SKF bearing: BB1B 1862021 B
72mm OD, 29mm Wide, 35mm ID
Seal on inside, shield on outside
I dont want to say a 27mm +2mm shim is a good idea
Don B (07-29-2016)
So does this work? As in this part number but a shim is needed? About to look into mine, may be time to do something.....
The SKF # is the exact bearing jaguar uses.
Typical bearings of the same OD and ID are 27mm vs the 29mm (our 14hu output bearings). So a 27mm double row angular contact bearing +2mm shim and +2mm camber shims could work (but i don't think its the best solution)
i don't believe 72mm OD is a standard metric shim size
