Differential Rebuild Thread
Old 03-05-2012, 08:39 AM
Count Iblis's Avatar
Originally Posted by avos
Me too, am only looking for some optimizations (and removal of needless torque reductions at some areas), but in Sports mode I will do some more, that way you will always have a choice.
Most of the time I am driving in normal mode even. The higher you go in engine power the more optimization you can use, but that’s something you will find out once you are there yourself. Also remembering you where planning to up the rpm, you would need to tune your TCM for that.
So if you want a buzz bomb, you need to up power and change your gear ratio, as that will not happen with a TCM tune.
A 'buzz bomb' occurs when the gearing is low(in concert with a remap) and you're driving on the freeway. It's down to personal choice-some here prefer the 3.74 or even 4.09 ratios- I don't. Over geared, under geared or ideal geared- makes no odds to me when the car is speed limited and the roads out here have low speed limits anyway.
'I can find out when I'm there myself'- very nice! I have been rather busy with other projects and you do enjoy a good poke at Thunder kitten and such like. Yes, perhaps I never learned when I was involved in the powertrain development of the XK 180 or the Jaguar XKR'R or even the R types and Aston martin V8 Vantage but someone online will put me to rights yet again about screw compressors and TCM mapping and re-gearing. Thank you my friend
  #102
Old 03-05-2012, 09:29 AM
avos's Avatar
Received 1,068 Likes on 761 Posts
No wasn’t meant like that at all, was just surprised that you were not thinking of a TCM tune, so that is why I said you will find out when you are there, and as not only you read these posts I thought it would be of benefit to others . So you have drawn a wrong conclusion here, except for thunderkitten of course LoL, but that has a history.
I find it unfortunate that you become so negative, but so be it.
  #103
Old 03-05-2012, 10:52 AM
I'm an engineer- of course I'm negative!
  #104
Old 03-06-2012, 07:14 PM
Sean B's Avatar
Received 1,363 Likes on 1,072 Posts
@ Avos - will you run the shift adaptation process I've read about on here, but not tried?
What will you be looking for after the re-program of the gearbox?
  #105
Old 03-06-2012, 10:34 PM
adam699's Avatar
Wel, for me today is the day after tomorrow, yesterday was tomorrow, or are you saying I was a day to early ? ;-)
and check if the TCM arrived...
  #106
Old 03-07-2012, 12:29 AM
avos's Avatar
Will do a couple of tests with measurements, to see if I can get more objective figures to work with. We will first start with the adaptation values that were already in the TCM, then to be sure that my current TCM has about the same adaptation values, I could reset both and compare that again (will be last test).
@ What will you be looking for after the re-program of the gearbox?
Ideas are there, budget not unfortunately, so it will take some time before I decide. To bring it again a major step forwards serious engine modifications are needed, being it for more boost or more displacement. Am certainly not going for more boost pressure, as that means more noise (also at cruising speeds), so that is out. Increasing engine displacement has been on my mind for long now, and I already have some rough ideas on how to do it and plan at least to go to 4.8.
Sorry, but that day was only to let you know if he could write also to the TCM as a test, this was for myself a milestone so thought it was important enough to share. The TCM has later been updated with a more suitable base map, and also some fine tunings as request. It is in the post, and I hope to get it today, sorry for the long delays
  #107
Old 03-07-2012, 04:20 AM
Sean B's Avatar
Friday to wednesday a delay! if it was England, we'd still be waiting to hear if he received the TCM!!!
Waiting patiently here.......fingers crossed Andre'
  #108
Old 03-07-2012, 08:47 AM
avos's Avatar
Oh boy, there was a postal strike this morning, so nothing for today I am afraid.
  #109
Old 03-07-2012, 04:04 PM
adam699's Avatar
Hopefully good things come to those who wait
  #110
Old 03-08-2012, 02:05 PM
adam699's Avatar
this wait is making me lose my mind
  #111
Old 03-08-2012, 11:40 PM
avos's Avatar
I Keep repeating "Good things come to those who wait ", that blocks the mind very well, thanks!
Am checking what can be wrong, I should have received it by now.
  #112
Old 03-09-2012, 10:34 AM
avos's Avatar
You should have seen the smile on my face when my wife told me that there was a package for me. Unfortunately it wasn't the one, after checking they mentioned that the guy who should have send it last Friday had forgotten it, so it left only yesterday and should arrive early next week, am slowly geting
  #113
Old 03-09-2012, 03:07 PM
adam699's Avatar
LOL. Well, today I found a locking 3.58 locally. I suppose it's a good thing for $400 with a front plate. So I'm going to buy it in hopes that the TCM can be reprogrammed reasonably. So for now I'm keeping my fingers crossed
EDIT: I'm "exhausted" with the whole differential fiasco. To turn things around and find a positive thing about the whole rear end being out of the car and the car on the lift, I ordered a full Borla cat-back. Should be way easier to get it in the car with the rear end out of the way. I think I got a good deal too so once it arrives I'll do a post on it and share the info where I got it from with anyone looking for a "deal" on one of these.
  #114
Old 03-09-2012, 08:25 PM
adam699's Avatar
Ok, here are the pics of what I'm picking up tomorrow.
Looks clean, but pretty leaky. I guess I'm wondering how hard is it to change the seals/axle bearings on the HU15 units. Do these units also suffer from the breather issue?
  #115
Old 03-10-2012, 04:59 AM
Sean B's Avatar
dunno about the breather, best to fit a new one, but the front seal isn't a tough job. Just make sure it goes in square. A dolly to knock it in is the best way made for the job.
  #116
Old 03-10-2012, 03:23 PM
adam699's Avatar
I picked up the locking 3:58 today i'll take the lid off to inspect it but just spinnig it by hand it feels nice and tight.
Came out of 1994 xj12 with 130k on the clock.
  #117
Old 03-13-2012, 05:33 AM
avos's Avatar
Have received the package, hopefully later today I can test drive
Update: Installed it, but unfortunately got an error. So the good news is that something has changed, just not good enough... Probably have to send the unit back again (although am awaiting feedback first), so this could take some time before we will finally know.
  #118
Old 03-13-2012, 09:52 AM
adam699's Avatar
Hmm, what kind of an error?
I should get most of the parts for assembling this thing today.
  #119
Old 03-13-2012, 10:06 AM
avos's Avatar
Should be a simple one I would guess, P1643. This could either be the unit having an issue due to transport (small chance), or it is in the specific programming. Am awaiting feedback now.
Changing just the gear ratio was a much simpler task, is this something you want me to discuss? Or do you want to wait for a fully tuned version?
  #120
Old 03-13-2012, 10:55 AM
adam699's Avatar
Well, it will all depend if I can figure out a way to slap it together and make it driveable in some respect. If I can live with it than I can wait for a full tune. If I can't than the gear change would be the way to go.
As far as the P1643, try to re-seat the TCM connectors. Sounds like the CAN bus can't communicate. I'd also try cycling the battery.
Quick Reply: Differential Rebuild Thread
