Dipstick Tube Nut
Dipstick Tube Nut
I appear to be missing a nut that keeps my oil dipstick tube in place. I went to check my oil level and damn near crapped myself when the whole tube started to come up as I pulled.
Does anyone happen to know what nut I need here?
Received 13,093 Likes
Hi Presence,
Since it is highly unlikely that any member of this forum has measured and kept a record of the size of the nut you need, why not visit a hardware store as Sean suggested? If you can't take a similar nut with you to compare sizes, just purchase one each of every metric nut in that size range, say M3, M3.5, M4, M5 and M6, along with matching lock washers.
Our local True Value Hardware has an excellent selection of metric fasteners, and most of the local auto parts stores carry a more limited range of sizes. If you return the fasteners you don't need, you can probably solve your problem for well under $5.00 even if you have to buy packages of 5 nuts and 5 washers in the size you need.
Note that the lock washer doesn't have to be metric, it just needs to fit over the threaded stud and under the nut.
Cheers,
Don
The following 3 users liked this post by Don B:
Since I will need to be pulling mine out this week anyway, what I will do is pull it off, take it to the store, and measure it to ensure that the thread and size is correct, and I will report back with my findings. I will be able to stop tomorrow evening and report back. I need to get a new bolt for the coil cover anyway.
Wait no longer ................... It is an M5 nut same size as the coil cover bolts and cam covers
If you put a spanner/wrench/socket on the bolt at the side of it on the cam cover housing you will probably find it is 7mm socket, your new nut that you will get from the hardware store will probably be an 8mm socket, because some automotive heads on the bolts/nuts are a mm smaller
That's pretty much the standard diy approach.
Or buy a few of each size that is close and stash them
for future use.
One could also measure the shank with digital calipers
in a pinch(pun intended!).
Your method is sure fire though.
for future use.
Good point, Sean.
According to McMaster-Carr (mcmaster.com), the maximum temp for Nyloc inserts is 250F, so it likely wouldn't hold indefinitely.
A serrated-flange locknut, a nut with integral lock washer, or a standard nut and separate lock washer should work fine. I would not use a deformed- or distorted-thread locknut for risk of snapping off the threaded stud due to the higher torque required to install the nut.
Cheers,
Don
XJRay (08-31-2015)
