Disable restricted performance fault on dashboard.. Radiator fan not working
Hello I have a restricted performance fault on dashboard and i need to disable it for a day, it may be a head gasket leak but the fault displays at times only , when it does display the car shudders badly on acceleration, fine when fault is not displayed on dash... Can I disable the display for a day easily, perhaps a fuse or relay or similar???? Also radiator fans are not working , where do I begin .. I like to check the obvious Stuff first ... All advice is greatly appreciated thanks, I'm just an amateur so go easy 😁 thanks Trevor
There are 2 ways in which the fans turn on . One is by the coolant temp sensor and the other is a command on by the A/C pressure switches . We'll test it by the A/C method .
Fuses first : # 12 / 30 amp Engine Compartment fuse box
# 14 / 30 amp Engine Compartment fuse box
# 14 / 10 amp Engine Management fuse box
Then run with A/C on and see if you get both fans .
If not you can swap the right fan connector over to the left and see what you get .
Don B (02-05-2018)
First off Trevor why do you think it could be a head gasket?
It sounds more like an electrical fault if it comes and goes.
Can you give us more info on the car, what year and is it XJ8 or XJR?
You can read the fault codes stored by using an OBD reader, there's plenty of info on this forum, basically connect it to the car and pull the DTC's as Motorcarman (Bob) has suggested - an essential little gadget when you own one of these cars...
Once you've posted the codes we can at least suggest a fix so you can rid of it permanently instead of just for one day.
Don B (02-05-2018)
The first thing to do in troubleshooting is to pull coil number 8 and swap it with number 7. Drive a bit and check the codes . Are you now getting P0307. If so then the coil from number 8 is bad and needs to be replaced. Since you are going to pull coil 8 to swap I would go ahead and change the spark plug while the coil is out of the way. The coil may be good and the plug bad.
When you pull the coils check for oil around them. If it is there is oil the plug could be shorting out. The cure for oil in that area is new cam cover gasket.
For your coolant loss problem the only way to good a good resolution is to have the system pressure tested. Your leak could be where the coolant is contacting a hot surface and evaporating off and you can't see it.
Biggest culprits are the heater feed and return underneath the intake manifold and the "Octopus" hose under the throttle body.
Don B (02-05-2018)
M12345678
07-14-2016 12:49 PM
jsmooth226
01-24-2015 12:47 AM
Elle924
29
08-08-2013 10:39 AM
