Disable Traction Control
Without a functioning ABS pump, the Trac Control cannot function. The Track control is basically an LSD diff which is automatically activated when needed (one rear wheel about to spin). The ABS sensors provide info as to which of the two wheels is about to start spinning and the ABS ECU will activate the ABS pump and direct pressure to the brake of the offending wheel
Trac control and ABS LIGHT
Thanks for the tips guys. Im not sure of how to interrogate the abs module. I plugged my OBD2 diagnostic tool into the car but it isnt telling me anything. When I shut the ignition off, the dash lights go away for a minute but come back on every time i start to drive again. This started a few dsys ago when i found myself in some snow and the traction control came on. Soon after that my idiot lights came on and i have no trac control now
very likely it’s this problem
