Disappearing coolant
I have recently, within 2010 replaced most all the plastic coolant parts that I know of due to leaks that developed. These include the thermostat housing / cap and thermostat, coolant reservoir and one small plastic line from he coolant reservoir to the thermostat housing.
Right now it is losing coolant enough to have to top it off once or twice a week. I don't see anything on the ground and don't readily see where it could be leaking. I am going to get a good look at it this afternoon as I have been busy. I wanted to know what anyone else's experience may have been along these lines. Or what else I may look for.
Any advice is well appreciated,
Pat
Pat
Sinister:
That sounds like you have a crack in the thermostat housing. Time to get the aluminum replacement. See archives for the way to get the old one off with the crowsfoot wrench.
Or better yet, someone suggested breaking the old plastic one, getting the bolts out. then replacing them with socket head cap screws.
Sinister:
To replace the connector do you have to replace the entire hose group??
norcaldiesel-
I was hijacking your thread a lil to reply to Sinister- sorry!
As to your problem, I am puzzled too. If it aint laking onto the ground, then it just about has to be going thru the engine. It could very well be leaking that much into the engine and running fine, though. My XJR had that symptom for a few weeks before the engine started showing white steam at startup. Look for 1 plug to be very clean.
I replaced all those pieces up front and on top, thermostat and housing/cap.. They are new and clean. That's what was confusing. I could not see anything and it ran fine. If it were a head gasket and losing the amount of coolant I am loosing it would not be running.. Right now the engine runs great.. I pulled all the covers off the engine and found it leaking under the coolant reservoir above the tranny. That funky "norma" connector.
My next trick is the pressure tester.
![Icon Shrug](https://www.jaguarforums.com/forum/images/smilies/icon_shrug.gif)
X308XJR
05-20-2019 06:50 PM
