DIY transmission swap
Received 1,815 Likes
Well, at least you got it in, now that rascal of a code. If your using the same shift indicator, that may be your problem (as you suspect)...https://www.carobdcode.com/p0705-jag...it-malfunction
Its really not worth anything unless you rebuild it, as you know, a straight used swap is $500, but a rebuild is minimum $2500, around $250 for the kit. Don't know if that's worth your time? You could go by a Merc and/or Jag Inde' and see if he's interested in it.
If you want to review how to break it down or find what might be the issue, Gary Ferraro is very knowledgeable... https://www.youtube.com/c/GaryFerrar...ch?query=722.6
