Do I need to reprogram a swapped instrument cluster/speedometer
I think i read somewhere before where if you swapped instrument clusters, the dealer would have to reprogram it for it to operate? But i have read of others just swapping them with no reprogramming necessary. My instrument panel is done for, I have an XJR but have found an xj8 cluster locally for $50; was thinking about picking it up; I would assume they are interchangeable. does anyone have any experience with this?
I say try it and let us know what happens. It is only $50. I know on Caravans and Town & Country vans the odometer data is stored in the BCM and a swapped cluster will get the correct mileage from the BCM. You do have to be careful in swapping PCMs and BCMs though because mixing one that has security with one that doesnt will cause it to lock out! I learned this the hard way.
willia (02-10-2011)
Received 2,192 Likes
its possible and yes they have to be programmed on "chipped" ignition keys. The key programming is retained in the I pack, youll need all keys and at least 2 for programming. Any missing keys will be deleted, but can be programmed later unlike the new smart keys with push button start operation(except the new 2011 XJ)
You should call several speedo repair shops about mileage, while I know you cannot change the mileage through Jaguar software, I met a guy in Moab Utah that owns a speedo shop in Cali. and he said he bought the software to programmed ALL I packs and mileage. He said the software and equip cost him 30k but that may have been an exaggeration who knows. I know software like that is expensive. But call around and ask because without this capabilty, speedo shops would be out of business if they dont expand and stay up with new tech. At the dealer level as long as the VCATs suffix's match ie 001, 005, 002 etc for the Ipack theyre considered compatible modules.
If you give EuroJag a ring in the UK with the model year and mileage - they'll do a near match. Or you can send a replacement to a mileage correction supplier, there're plenty in the UK, but I don't know about were you are!
http://www.eurojag.com/
so do I need to keys or could it be done with one and the other key be deleted untill I get another one
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
bcm, cluster, instrument, jaguar, milage, mileage, odometer, programmed, repair, reprogram, speedometer, swap, xj, xj8, xk8
