Do I swap shifter cable to fix VERY stiff to shift from park to R?
Jgate is VERY stiff to shift out of the park position (smooth once in/past R), looking underneath the rod to the jgate bends visibly from tension until the cable begins to move.
Will a new shifter cable fix this, or could the tension be from the transmission end under the car?
Not the nicest job, but not too difficult either.
You will quickly be able to see if it is the cable or the transmission itself.
Good luck.
To test the cable resistance requires unhooking it, by that point it makes sense to change it already (since I'm paying for labor, not doing it myself)
Is this a logical assessment and conclusion?
How do you grease the cable?? Just got the replacement but only the last couple inches sticks out from the sheath.
