Does the 3.2 engine has a Secondary Timing Chain Tensioners?
I know that the topic "Timing Chain Tensioners" is one of the most discussed among XJ8 forums, but there is one question I still can answer to - does the 3.2 engine have a Secondary Timing Chain Tensioners? I'm asking because when I check the EPC there it says, that only 4.0 and supercharged engines have Tensioners on the Secondary Chain... for the 3.2V8 it's shown only to have Primary ones...
I'm following two bids on Internet about timing chain tensioners with part # C2A 1511 / C2A 1512 / JFB 10607B, but I'm not that this is the only thing I'll have to replace... As I see in other recent threads on the forum, people are ordering entire kits. Do I really need it?
Most folks only replace the secondary tensioners and the required 4 bolts. While there have been a post or two about the primary shoes cracking the secondary tensioners are the cause of many engine failures.
Most in the US now order the Ford Thunderbird/Lincoln LS tensioner part numbers as they are substantially less than the same parts with a Jaguar part number. Don't know how this will work in Bulgaria but here is the list of Ford part numbers in post 4 of this thread:
https://www.jaguarforums.com/forum/x...34/#post330655
The reference to the FelPro gasket set will not work on you AJ26 engine.
xjrjag
10-27-2021 11:48 PM
FS[MidWest]: Secondary Timing Chain Tensioners
Bcrary3
09-12-2015 08:43 AM
Bcrary3
08-31-2015 11:29 AM
FS[MidWest]: FS: 1999 VDP *lots of pics* in mid-Missouri
souldoubt
08-25-2015 08:15 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
