does anybody have timing tools in san antonio to rent 98 vdp
hello, need to do my tensioners next week wondering if anyone was intrested in renting their timing tools before I go rent from one of the retail places.(not sure i can make their return deadline). job will take me at least 4 days(4 hrs a day), also doing thermostat housing,waterpump,radiator,tranny fluid/filter, adding external tranny cooler and thermostat,sparkplugs, and detailing engine bay.Anything else i should consider? I'm in San Antonio,TX and the car is 98 vdp.to top it off just found a 2001 vdp that needs same job done for $2000 if can get it cheaper ill probably be the owner of 2 vdps for under$5000.Sweet i hope....
BTW thanks for the Christophers Foreign cars link, jimlombardi. Now I have a good plan b.
Check with the local Lincoln/Ford folks as they are used on the Lincoln LS/Thunderbird. Several have been able to rent the tools from their local dealers. My replacement of only the secondary tensioners took 4 hours and I cleaned the top of the engine as I went.
prelude4ws (08-15-2011)
philwarner
09-05-2015 10:05 AM
