Does anyone know...
A module with the correct part number can be made to operate the car, by running the immobilization app in SDD to sync the security system so the PATS System will allow cranking and fueling.
Cheers,
A new unused ECM is programmed as a new module. Doing that burns things like the VIN, PATS keys and wheel size into the new part. From then on, the only thing that can be done is configuration changes. If it is ever again programmed like it's a new, blank module, it's toast. It can be moved to a comparable car, but all you can do is sync the PATS and security system so the car will start and run.
In other words, there is no way to make a used ECM "right" in another car.
Make sense??
Make sense??
JOsworth
52
12-29-2011 03:02 AM
