Does Anyone Know Which Fuse is for the Trunk Lights?
I 'm charging my battery and want to keep the trunk open (as suggested by the charger manufacturer)... but the 2 small lights (which illuminate the inside of the trunk) are on. Does anyone know which fuse to pull out to turn them off? (And which fuse box, please)
Thank you,
SirJag
Thank you,
SirJag
I am not sure which charger you are using but if it is an automatic charger it will still charge the battery with the boot lights on.
I can set the maximum amps on my charger and it will reduce down to a trickle charge rate that I can also set. My current settings are 2amps down to 150mA.
What are you charger's ratings?
SirJag
Yes. I wanted to be absolutely sure.
I also did this with my refrigerator. You should have seen how difficult it was to get in there with that damned watermelon taking up one entire shelf. Of course, wearing the bulky fur-rimmed-hood parka made it that much more difficult. ;-)
SirJag
SirJag
rsa760041
23
09-25-2015 01:33 PM
02jagstype
09-04-2015 08:20 PM
