Does car need to be running to read OBD codes?
Old 05-14-2015 | 05:26 PM
Presence's Avatar
Default Does car need to be running to read OBD codes?
I bought myself a little Vgate Bluetooth reader, and downloaded the Torque app. The scanner paired with my phone, and I *think* Torque found it, although it kept displaying messages up top about protocol scanning or something.
Anyway, I know I have codes to read as I've had the CEL and Restricted Performance lights come up (the latter intermittently.) But when I choose to display codes, it says nothing is found, no matter which log I choose. However, I thought I saw an error message flash quickly about "unable to communicate with ECU, is the ignition on?" Does this need to be the case? I need to start the car?
Old 05-14-2015 | 06:16 PM
test point's Avatar
The engine does not have to be running but the ignition switch must be in the 'run' position.
The cheap eBay OBDII/Bluetooth converters have a very high failure rate. I have 1 that works and 3 that do not.
Old 05-15-2015 | 07:37 AM
Presence's Avatar
Thanks for the confirmation - that worked. I thought I'd read the OBD port was powered full-time (and it does appear to be) and hence the codes could be read at any time.
The reader worked and I have the Lean Bank codes (0171 0174) and I've read enough on this forum to know where to at least begin!
fast40driver
04-19-2024 07:24 AM
hafren
08-30-2023 03:42 PM
msdg137
09-16-2015 06:24 AM
SingBlueSilver
08-27-2015 02:20 PM
NinoGrimace
08-26-2015 05:15 AM
Quick Reply: Does car need to be running to read OBD codes?
