Does ODB-II work when the car is off? (will the battery drain by leaving connected?)
It probably will drain the battery.
But why leave it connected?
Your car will communicate with the OBD-reader only when the ignition is turned on.
So if you turn the ignition off the connection will get cut anyway and the OBD reader will still draw current.
(At least that is the way my OBD reader works.)
David
David
For those who want to learn from my stupidity, the short answer is yes.
Bluetooth continues to transmit and you can indeed connect to it when it is merely plugged in even without the keys in the ignition - you cannot communicate with the ECU without turning the key to the ACC position, but you most certainly can drain your battery by leaving the device connected overnight
hafren
08-30-2023 03:42 PM
Isoruku
06-19-2020 12:54 PM
FS[SouthEast]: GenRad GDS-510 scan tool
johnnie ryall
10-19-2015 09:44 PM
SingBlueSilver
08-27-2015 02:20 PM
