Does the XJ8 speedo read low?
I'm going to check tire size as soon as my wife gets home, but I noticed the same thing a week or so ago on a run to Dallas. I hit the interstate and not being in any real hurry set the cruise between 70-75 and it seemed I was passing everybody. I set it the same for the ride back and pulled up a GPS speedo on my phone. I've hand clocked my MX5 to calibrate custom gauges and found the GPS to be very accurate @ 60mph. According to it I was bouncing between 74-76 with the cruise set at 70, which means I was pushing 80 for 3 hours on the way to Dallas. DPS must have been feeling generous.
Just a thought, but each specific vehicle might have a calibration that is unique to the tires that were original equipment. In other words, if a car was built with a wheel/tire upgrade option, it may receive a calibration that is different from the base model.
The calibration should match the tire fitment sticker on the specific vehicle.
lol that's the other thing. I have only gotten 1 ticket in the Jag and it was going 40 in a 35. The speedo was dead on 40 there. I can drive up I-35 right at 80 mph and I am blowing cars off the road, but never seem to get attention from state troopers.
Nice tread pattern
26.1" overall diameter, 798 revolutions per mile.
For those who are wondering what the point is, it is an attempt at compiling representative "revolutions per mile" figures with a known speedometer error.
The speedometer knows nothing except revolutions over time, so enough "revolutions per mile" observations will directly translate into a pretty good guess as to the most desirable "revolutions per mile" target when purchasing tires. This is closely related to the diameter but not the same thing because it varies according to sidewall flex. The manufacturers publishing this figure will run the tires at load against rollers to determine this figure.
Only 2 reports so far, but, they are consistent at 798-803 revolutions per mile resulting in a 1 mph under reading by the speedometer.
assuming that the 1 mph error is at 60 mph,
meaning that 15 or so "revolutions per mile" will only result in a difference of 1 mph or so, and that the target is 814 "revolutions per mile" when considering tires if speedometer accuracy on a X308 XJR is being considered.
Code:
average revolutions per mile for 1 mph error (798 +803) / 2 = 800.5 correction for 1 mph error on low side 800.5 * 61 / 60 = 814
JaguarXJR02 (04-21-2011)
That's because speedometers are not allowed any error to the downside, but are allowed "X" percent to the upside.
rsa760041
23
09-25-2015 01:33 PM
carcycle
09-07-2015 10:22 AM
