Door Lock Actuators
Nalley Jaguar , JPAM (our vendors )
If those are not available you can try these
www.motorcarsltd.com
www.jagbits.com
www.jagbits.com
In the UK, have you tried David Manners or British Parts UK.
Or a quick UK Google for Jaguar spares will give you a decent list of breakers.
Did you take everything out or can you just take out the lock fitting ? Sorry just realised im in the XJ forum I have an S type
I had to loosen everything in the xj rear to get the actuator to a spot where I could remove it. Going with a aftermarket likely means you'll need to solder it in so you should just be able to remove the actuator and the harness, solder then put back in. It isn't the easiest job to do as access in any door pretty much blows.
OK Guys, I guess this is my weekend for somewhat stupid questions....My front passenger door actuator goes down when locked, but then immediately raises up while the other doors remain locked. Is this going to be an actuator problem, or an electrical signal from somewhere else raising this one actuator back up. Also, upon looking at a spare left handed door I have, it would appear that if I replace just the actuator, that I will need to splice into existing harness as it has two leads on it from one plug. Is this so, or am I confused? Thanks in advance for your patience.![Icon Couchhide](https://www.jaguarforums.com/forum/images/smilies/icon_couchhide.gif)
Duh...just re-read benebob's response which answers the splicing question.
Ralph
Ralph
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
Ipc838
09-13-2015 03:27 PM
