door mirror problem
door mirror problem
1998 xj8 sovereign, the door mirrors have both just decided to aquire a mind of their own!
as soon as I unlock the car both mirrors adjust themselfs by turning fully to the left and down,this has only just started since I disconnected the battery briefly.
it means I have to re adjust them every time i get in the car.
any ideas?
any ideas?
not so far as I know, nothing has been touched, ive disconected the battery before without problems,ie to recharge etc, its not a major problem, more of a pain in the a**! I only disconnected to clear codes (which was sorted out by cleaning the MAF) seat and steering wheel remain unaffected
Set the mirrors and seat where you want them and then press the memory key 1,2, or 3 on the armrest until it beeps.
I had this problem also and instead of using set button 1, I used set button 2. When I used button 1 it would revert to the bad positions so don't use 1.
Whatever you do, don't press button 3 if your wife is with you because an 18 year old Thai girl appears in the back seat and starts combing your hair, if you have any. Caught me out a couple of times I can tell ya !
You are lucky! Here in the US, a Bong pops out of the center console. And I Don't Smoke Weed! It's tough trying to explain that to the officer that just pulled you over for excessive smoke. Although, from the Contact High he received, he was giggling so much he let me go. But not before confiscating all the munchies I had in my car first!
any ideas?
any ideas?
Little update on topic:
I have tried to fix the problem several ways:
1. I tried the big reset thing.
2. I tried reprogramming the fob.
Anyway the problem remains, mirrors adjust themselves in position that however doesnt look like a memory of someone, left mirror goes far left and far top, right mirror goes slighltly left and medium down. It only happens with fob opening, when I open car with the key mirrors stay as they are. I dont have any seat memory options.
any solutions? please help!
any ideas?
any ideas?
didnt get any bongs,wild girls just same old sh#t ....any more ideas??
You may have fob #2 and it is reverting to the #2 memory positions even though you have #1 properly programmed in the car.
Try reprogramming all 3 memory positions on the armrest to the same setting and the fob will have no choice but to go to your desired positions for the mirrors.
If this doesn't work then call in the exorcist or witch doctor because your car is obviously possessed by demon(s.)
.........or hit memory setting 3 and enjoy the bong/girls, but don't exceed 88 mph and 1.21 gigawatts in this setting or you will end up back in 1973, lol.
Vector
Wolfy
05-28-2024 08:06 AM
99xk8guy
06-05-2023 06:28 AM
