door speakers problem
Hi,
I have XJR from 2000 with the premium sound system. I just bought it and now I'm in the process of fixing the small faults.
The problem is that the speakers in the doors on the right side do not work. I mean the big ones, the back door has also a small one which works fine.
Since both of them (back and front) are not working, is it possible that there is some common plug which is disconnected?
Any idea where to find some info about how the sound system is connected and were in the car are the cables?
thanks a lot,
Asen.
thanks a lot,
Asen.
If two speaker are out, but the tweeters are still working, it's likely the speakers... it can't be the head unit, or the wiring - they're all wired separately - but the rear speaker is wired in parallel with the tweeter, so if the tweeter is working, the speaker should be too. It could be the amp (for the front speaker only), but not as likely as the speakers.
Here's the stereo wiring from the electrical diagram for 2000 XJ series Premium Sound: (download the complete diagram yourself from: http://www.captainjaguarscathouse.co...ec%20Guide.pdf )
![Name: PremiumSound.jpg
Size: 81.7 KB](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/178944d1501301781-door-speakers-problem-premiumsound.jpg)
The factory Jag speakers are a compromise. I would not replace with those.
So now what to buy is a tricky question and the range of answers you get will be based on taste. Here's what I'd look for:
Sensitivity - around 90db (1W/M) The more sensitive the less power needed to drive it.
Frequency response - 50hz - 20,000khz
4 Ohm
There are many speakers out there and they run a wide range in price. It all depends on how you listen. If you are on the phone or do not normally listen at higher volumes, invest less. If you want the best sound considering the power output of your stock system, spend more.
4 Ohm
99xk8guy
06-05-2023 06:28 AM
