Door Speakers/Tweeter Replacement
Guest
Posts: n/a
I am looking for an aftermarket component speaker set to install in a 98 XJ8 with a standard system (without Harmon Kardon premium).
I believe the door speakers are 6.5 inches.
Does anyone know the size of the tweeter behind the door handle (3/4 inch, 1 inch, etc)?
Does anyone know a decent aftermarket component set that will fit both the existing locations without modification?
What about the crossover? Does one already exist (and where is it located)? Or, will it need to be replaced/added with installation of new speakers?
Any help is greatly appreciated.
Thank you.
Thank you.
the door speakers are 6.5", can't really help with the tweeters though, as they are quite unique and have a built-in clip to hold them to the door handle pieces
however, i have managed to replace mine with some reasonably large tweeters, they were simply glued into place with a hot glue gun, and this is perfectly fine
you may have clearance issues with the mesh covers though, but my if you use smaller tweeters this shouldn't be an issue
as for the crossovers, there isn't one, only an inline capacitor (i think?) wired to the tweeter. if you are going aftermarket you really shouldn't be bothering with anything that doesn't have a proper crossover, but there is plenty of space in the doors to mount them
I am planning to replace my front door speakers soon - what kind of a job is it to install them? Is it necessary to pull off the entire door panel?
***Nevermind, thanks. I just found many posts on this subject. Pictures even. Love this place...
Infact, the speakers are not 6.5's there 5.25's.
I guess there as a change over period in the models.
My question is, when buying 'component style speakers' with a cross-over box and a tweeter, is the cross over needed or is there just a direct feed for the tweeter?
Just what is the best way to tackle job use the crossover box?.
Any help would be much appreaciated, i just bought a 20001 XJ8 with 100 on the clock and the speakers are flat blown.
Also its very confusing when people tell you the Wrong size in here, ive been to 3 places to get prices on 'for them to do it' and the price is way out the look, al three places bought up 5.25 or 5 1/4 on the computer, even when i ordered my stuff i used a "will these speakers fit your car' option on Amazon.com and sure enough, 6.5's dont fit.????
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
On every XJ8 I've seen they are fitted with 6.5" and this is HK or Alpine. Don't blame the forum for your mistake if you get the wrong ones, I'll say this, it's your car, and pulling a door panel to check is naturally common sense before relying on a forum as you shell out a couple of hundred on 5.25's.
Conflicting info on the x-overs, some say they're internally crossed in the amp (premium system) or, full range in each feed.
What system do you have in the car? standard or premium?
Thats BS then, if all the shop computers reccomend 5.25 but then they turn out to be 6.5s...hmmm.
i belive its just a standard, what i meant with the speakers is, i went to car toys and they checked in the computer and found the car needed 5.25s, i went to best buy an they checked the computer, it said 5.25 and when i ordered on Amazon there "will these speakers fit your car" drop down also came back with 5.25? Yet if you say there 6.5's then i just ****ed up, becuase i ordered 5.25s? ill drop a pannel off today and see what i find, will have to return them i guess?.
![Icon Saywhat](https://www.jaguarforums.com/forum/images/smilies/icon_saywhat.gif)
Any ideas would be great, i ordered what i was told to order from 3 different vendors?????
got a nice set of blaupunkt componet speakers that will cover my upper mids and highs but will now need a base curcuit... that will sound cool pumping out the "beautiful south" in Houston. lolz
![Confused](https://www.jaguarforums.com/forum/images/smilies/confused.gif)
I replaced my 1997 XJ6 speakers today. (About a 3 hour job.) I Installed 5.25" speakers. They fit ok but are a smaller diameter than the original speakers. (I too followed the listings I found posted and online) - I purchased a set before I took off the panels.
I measured the speakers and they are 6.25" OD. The Inner diameter at outside of the foam surround measured 5". On my car, 6.5" speakers would be a tighter fit. (Perhaps different sizing for different speaker manufacturers?)
My replacement speakers have a 4 screw pattern versus the 3 mounting hole pattern that my stock Phillips speakers have. On my door panels, there are two round area where the speakers can fit. The outer area sits about 1/4" higher than the lower area. The lower area has the panel leather folded and stapled to it. My 5.25" speakers fit just into the upper opening. I drilled 4 new holes and screwed them down. They sound much better than the original blown speakers. - The surround foam had separated from the cone.
I recommend that you purchase a few spare door panel door hooks before you start the job. It seems like no matter how careful you are a few break.
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
KarimPA
09-03-2015 07:32 PM
