Door Trim
Hello Bill, as silly as this will sound, why not try sticking the trim down with something like Silicone? This can be hidden easily behind the panel as you will only need a small amount and it's easily removed also should you need to remove the pannel for any reason. Either this or a double sided sticky pad.
Great minds, Stu.
I had not thought of the silicone but was thinking since it is only the corner of the driver's door and the passenger door of using doubled sided tape. The rest of the trim on both doors is fine and this is not sticking way out. When you were thinking of silicone were you meaning like a silicone putty?
Thanks,
Bill
Thanks,
Bill
Glad you found a fix that worked. I meant the silicone that comes out of a tube, like what you might use in a bathroom. We use it at the depot for sealing the floors of buses, or areas of the bus which requires protection from water. But it is also pressed into service as a glue when a easy removed solution is required.
Ta, S.
Ta, S.
Okay, haven't revisited this in a while. Tried the double sided tape but did not work. I didn't want to remove this wood door trim (both front doors have the problem). Not sure I want to try the silicone methog recommended. What's the best fix...how do I remove these pieces from each door?
Thanks.
Bill
Thanks.
Bill
Here is the PDF file extract for door veneer panel r&i. Click on the PDF file name:
5) 98 jaguar xj8 front door finish panel 76.47.11.pdf
I put out a reply yesterday on door mirror thread for r&i
If you want to see the rest of the PDF files that give all the instructions on how to remove and install the front door panel then
click on this website link:
https://www.jaguarforums.com/forum/s...ad.php?t=42677
Go down to reply #6
Titled: Second post on Jaguar JTIS information on XJ8 door mirror r&i
Go down to reply #6
Poet
10-06-2015 09:40 PM
1964Daimler
09-09-2015 11:28 AM
