Door trim piece replace?
are you talking about the weather seal, Jaguar call it a waist seal, the chrome strip fits into? they're fitted down onto the top of the door panel, sikoflex holds the front bit to the door, not much you can do if the chrome bit is sticking out, apart from replace the whole thing. Around £80 new here. Don't know the part number for the long wheel base.
You can either use a heat gun, but be carefull not to get it to hot, or you can use dental floss and cut through the tape.
Another solution is 3M adhesive remover.
To put it back on you will have to use some automotive grade ( usually grey with a red peel-off backing) double sided tape that you can get at a part sore.
