Door won’t open from inside
Driver door will not open from inside. I opened the door panel and saw the plastic base of door handle was cracked and the cable has a slack. Fixed the crack but after a few open and shut, the inside door handle seems stuck. Do I need a new cable and interior door handle?
Received 1,813 Likes
I recently used this exact cable to remedy mine.
https://www.ebay.com/itm/Jaguar-XJ8-...%7CModel%3AXJ8
Highhorse (03-22-2018)
2003 Jaguar xj8
My door handle is connected to the actuator which I replaced a couple of years ago however, the handle broke and I had to replace it. It worked fine for a few months and then all of the sudden stopped working. I took the panel off and nothing is broken or detached, but won't open the door. I always have to roll the window down in order to get out of the car. Is there some kind of adjustment I need to make? You seem to be the guy to ask.
King Charles (11-25-2019)
Sharrieff
07-09-2013 09:34 AM
