Down shifting hard and at stop feels like hard thump
Received 1,813 Likes
Welcome Phalliday, please introduce yourself and your Jag here.... https://www.jaguarforums.com/forum/n...-intro-must-5/ ....be sure to review the site rules, it only takes a couple minutes.
Are you sure its the trans downshifting hard or perhaps could be bad jurid coupling or universals that may be binding when downshifting?
Have you ever changed your fluid and filter? Off hand, if it is the trans, it sounds like a sticking valve and a simple fluid change may be your cure?
Highhorse (08-15-2018)
Received 2,193 Likes
this is fixed 90% of the time with a transmission ecu(tcm) reflash with new updated software. If you have never changed the fluid and have over a 100k I personally would be very cautious. A trans that has been running ok with old dirty fluid suddenly may no longer shift correctly and slip with new clean fluid. the filter is the pan and youll need a elect sleeve and 5 liters fluid including a new pan and updated larger pan bolts. Then you need a pump to get the fluid in and car level off the ground. Not impossible to do in the driveway but definitely a royal pain in the butt.. Then the tcm should be reflashed along with the engine control module. This can only be done at either a dealer, Jaguar independent shop, OR a trans shop that definitely has the correct software to update a ZF and ecu. And this is THE FIX from ZF for this issue. there ya go
atom069
03-02-2010 09:37 PM
AGLXTYPE
12-23-2007 06:47 PM
