downpipe / catalytic converter removal tips?
Hi folks, Just wondering if anyone has any tips on how to remove the very well concealed downpipe nuts on my '98 XJR. I fabbed up a new exhaust and i would like to make some downpipes to match. My main issue is the stud closest to the rear of the block (i'm sure i can break the studs on the other 3), I really cannot comprehend what angle i need to get to it at without having to hoist the engine up about 6 inches. I may be dense, but any tips or tricks would be great. Thanks a bunch, Greverrr
My access is from the top as well. The drivers side is naturally more tricky, but the stud that is located most central and closest to the block on both sides is my main problem. I may need to cut and weld a 13mm wrench or socket and rod in a non conventional shape in order to compensate for spacial and leverage issues. Was hoping there was an easier way, but it seems i'll have to tough it out.
99xk8guy
06-05-2023 06:28 AM
Aus V8S
11-13-2015 11:01 AM
rachelstr
09-03-2015 12:59 PM
