Downsizing tires
Downsizing tires
Tired of paying $200 a tire and putting a lot of miles on my 03 xjr With factory 18s by commuting to school so I have decided to downsize the wheels to 16s. My dads 03 xj8 is only $80 per tire. Looking for aftermarket 16s of same width as xj8 in black with maybe a silver lip. Anyone know any sources? My car is the regular xjr so I believe 16s from xj8 would fit with stock brakes.
I've heard this also, but it would depend on rotor size, if fitted with 355mm discs at the front and 350mm at the rear, 18" is the rim, but if standard discs of 325mm then you could fit smaller rims.
I use a set of 17" from a late 90's XK8 for my winter set with snows - so they will work.
Check with a local dealer -- mine still had quite a few take offs from people switching out the OE's for wires. They had a full set for $300.00.
FS[MidAtlantic]: 1997 XJ6 VDP $3,900 - Very RARE Anthracite on Warm Charcoal
42Ajd
09-26-2015 07:04 PM
