Dreaded ASC failure, Eng fail safe mode
Today my son and I were headed to lunch when a Mazda speed came up from behind and started acting up. I punched it pretty good from about 40 mph to say 90 ( don't judge my parenting skills) and then it all went south, yellow/red light, ASC fail, engine fail safe mode. Limped to the nearest parking lot, turned it off the restarted it and it ran fine the rest of the day. All research leads to a failing throttle body but I'm surprised that would be the case at only 54k on it. All I seem to see is "used" (mines used) or "rebuilt" ones. I don't need the thing leaving me "limping" somewhere. PS, no codes thrown or pending codes.
You can try disconnecting the various plugs to the throttle body and spraying them with electronic or contact cleaner, but first disconnect neg. batt. cable.
A couple of members have suggested that infrequent use allows corrosion to occur on contact surfaces in the throttle body and repeatedly flooring the throttle a few dozen times (engine off) cleans them.
But grandell has the final solution if nothing else works.
From what I've seen in the XK thread, it's not the upper range of the track that's the problem, it's that the lower range wears and cracks, and you lose contact when you come back off the throttle, not when you're flooring it.
TBH there are probably a few common failure methods for these, whether it's upper track, lower track, or the pin connections/plug.
JTsmks (01-29-2017)
