The Dreaded P0328 OBD code
Old 03-31-2018, 06:05 PM
Carnival Kid's Avatar
Received 1,010 Likes on 613 Posts
Default The Dreaded P0328 OBD code
So today I had the "limited performance" occurrence, basically the motor quit when revved over 3K, it did it several times. And I get the P0328 "knock sensor 1 circuit high bank 1 or single sensor" code.
It did this a couple weeks or so ago, I inspected and jiggled/cleaned the knock sensor wiring connections and hoped it would go away, but I ordered two new knock sensors in case, and sure enough, here it is again, so I guess I will replace at least one of the knock sensors. My question is, which one is "knock sensor 1, bank 1" ? Driver's side, or passenger side (USA)?
And, are there any other tests I should do? Or is it likely that replacing the knock sensor(s) will cure the problem?
Thank you in advance. And Happy Easter everyone.
Old 03-31-2018, 07:35 PM
Highhorse's Avatar
Received 1,798 Likes on 1,320 Posts
I was going to toss this to you and it would be done, but there are no pics anymore... https://www.jaguarforums.com/forum/x...ine-faq-45963/
Let's see, I believe JimLombardi had one also...https://www.jaguarforums.com/forum/x...t-1-2-a-76815/
The following 2 users liked this post by Highhorse:
Carnival Kid (03-31-2018), Don B (03-31-2018)
Old 03-31-2018, 07:57 PM
Highhorse's Avatar
This is from the X308 Workshop manual
The following 3 users liked this post by Highhorse:
BaxtersJag (04-03-2018), Carnival Kid (03-31-2018), Don B (03-31-2018)
Old 03-31-2018, 08:46 PM
Thank you HS, I will replace the "right side" (passenger US) knock sensor and hope that fixes the problem. I have to take the car in for the Transgo transmission mod on Tuesday, so will probably wait until later in the week for this knock-sensor fix.
It sort of seems ironic that the knock sensor, which is supposed to be a "warning device" becomes the primary problem. (unless there really is another underlying real problem other than the knock sensor?)
Will let everyone know the results (of both transgo and knock sensor) as and when.
Old 03-31-2018, 08:47 PM
Received 13,103 Likes on 6,529 Posts
Hi Carnival Kid,
Just in case we guess wrong, please add the year, model and engine details of your Jaguar to your signature line (User CP link above).
Assuming it's an X308, here is the cylinder numbering chart:
Regarding P0328, here is the listing from the DTC Summaries manual:
Note that Knock Sensor failure is the last possible cause, and the more likely causes are poor contact with the block or a problem with the wiring/electrical circuit. This could be something as simple as the electrical connector being loose or contaminated with oil or coolant. It would be worth ruling out all wiring issues before replacing the sensor.
Cheers,
Don
The following 4 users liked this post by Don B:
Carnival Kid (04-01-2018), Highhorse (03-31-2018), MountainMan (04-01-2018), XJRay (04-01-2018)
Old 03-31-2018, 10:37 PM
Originally Posted by Don B
Hi Carnival Kid, Just in case we guess wrong, please add the year, model and engine details of your Jaguar to your signature line (User CP link above)..
Don, I checked the CP link, I think I have my details listed? If not, 2001 XJ8 4.0 VDP. (US)
Hi Carnival Kid, Note that Knock Sensor failure is the last possible cause, and the more likely causes are poor contact with the block or a problem with the wiring/electrical circuit. This could be something as simple as the electrical connector being loose or contaminated with oil or coolant. It would be worth ruling out all wiring issues before replacing the sensor.
Don, thanks for that, I will try cleaning block contact and checking terminal connections first. Hopefully I can find something obvious.
Old 03-31-2018, 10:41 PM
King Charles's Avatar
Received 1,021 Likes on 741 Posts
CK your details are not visible in your sig.
Old 04-01-2018, 06:22 AM
KC, I'm confused, where are my vehicle details supposed to show up, I have them listed in "my signature", and "about me"?
EDIT,.........Ah, I think I see them now!
The following 3 users liked this post by Carnival Kid:
Don B (04-01-2018), King Charles (04-01-2018), Norri (04-01-2018)
Old 04-01-2018, 08:25 AM
Highhorse's Avatar
Now your sig is showing CK...
Old 04-01-2018, 10:39 AM
This morning I tackled the Bank 1 knock sensor replacement. Pretty simple once you've done one (and had all the proper guidance from this wonderful forum). The Jaguar engineers could have put it in a more inconvenient place, but I guess they didn't have time to find one and figured, oh what the hell, lets run it along this equally inconveniently-routed heater hose!
I was surprised how tight the nut holding the sensor was, but was pleasantly surprised that the sensor itself was loose once the nut was removed, and could easily be removed with a pair of those extraordinarily long needle-nose pliers that I only find a use for once in a blue moon. I sprayed the revealed stationary knock sensor with electrical cleaner, and re-routed the new sensor, a bit of a pain, but not too bad.
As per forum advice I purchased the $32.00 272940880300 knock sensor listed for the 00-06 Jag S-type 3.0L V-6 instead of the $130-$175 one listed for the XJ8, and so far it seems to work fine.
I took the car out for an early Sunday morning test ride, revved it up to 7 grand with no problems. Hopefully that was the cure. And I have another spare sensor for the left-hand Bank 2 should I need it.
Thanks once again to all on the forum, this place rocks!
The following 2 users liked this post by Carnival Kid:
Don B (04-01-2018), Highhorse (04-01-2018)
Old 04-01-2018, 12:33 PM
Highhorse's Avatar
Good deal CK, I have to do mine and I have to remove the SC to get to it...joy
Old 04-01-2018, 12:39 PM
That makes mine an extremely simple job!
Carnival Kid
03-17-2018 06:17 AM
RJag
05-20-2013 05:26 PM
Karaudio23
11-18-2012 01:14 PM
ASE Tech
02-29-2012 09:32 PM
The Coupe
08-26-2011 10:24 PM
Quick Reply: The Dreaded P0328 OBD code
