Dreaded rust
Dreaded rust
Ceramic coated my XJ8 on Thursday and while going over the body saw this:
The car was only resprayed completely in March 2019, so a bit disappointed. I went back to the sprayer who wants £550 to cut out rust and re-plate it. Not sure what to do? Thought it would be cheaper to sand it down, treat with rust prevention and fill it. Would welcome forum members comments please.
For a permanent repair cutting and replacing is the best way. Considering your location I expect the rust is from the inside, so grinding the inside and outside surfaces, treating rust, then coating inside surface with epoxy and painting outside would likely hold up much better than just doing the outside.
Whenever the paint bubbles like that its because the rust has penetrated the metal from the back side. Water didn't go through the paint and do that, it came from underneath. And usually when you see a rust bubble on the surface, its just the proverbial "tip" of the iceberg. The solution is of course to move here to Texas where its relatively dry.
