Drive Shaft Removal in order to get to fuel lines
good evening fellow members- I am attempting to replace fuel pumps on my 2000 xjr- and have decided to follow the tank removal method- in searching the forums I have found great advice and instructions- some of the instructions call for removing the drive shaft and the brake cable in order to get better access- has anyone had any experience with the drive shaft removal- I have seen posts that reference marking it - can anyone expound on that - I am hoping to get some better directions how to handle that driveshaft situation before I tear into it - thanks for any all help. Cole
Don B (05-13-2018)
Don B (05-15-2018)
Don B (05-15-2018)
Thanks Bob I want to do it right and dont want to over complicate what is already a challenging job getting the tank out and getting the hoses disconnected from the tank seems to be a challenge without a lift- I am putting it up on jack stands to support and going underneath- thanks to you and the forum I will have a lot of good advice to get it taken care of. Thanks again Cole
carcster
03-11-2014 12:49 AM
penguin
03-18-2013 12:10 PM
