Driver door buttons don't work.
Hey all, it's been a while since I posted here lol. Just wanted to ask if anyone else has had issues with their window control buttons and mirror adjustment buttons? Mine are doing a very weird thing where sometimes they work and sometimes they don't. When they don't work, either they don't do anything when pressed, or they start opening other things they shouldn't. For example, the drivers window button should open the drivers window, but instead it opens the rear right passenger's window. It makes no sense. Then the rest of the window buttons don't work.
Also if anyone could get me help on how to replace the key lock motor on the driver's door, since turning the key doesn't open it anymore. Thanks.
If water has gotten in there the circuit board traces might be corroded and an open circuit may be the fault. You'll have to remove the door control panel and inspect the circuit board. Clean and solder the missing sections of the traces. At least that happened to one of my cars which was like that when purchased. You'll have to look closely to see the problem. Probably the power traces are the usual suspects.
ericnunez (07-12-2023)
The module you referenced is the DOOR CONTROL MODULE.
The switchpack in the door can fail if water gets in it.
I used to replace Driver's Door Switchpacks after customers got their windows tinted.
Installers would 'squeegee' the water from the window and film onto the switchpack and destroy it.
ericnunez (07-17-2023)
JeremiahLovesJags
10-04-2022 07:22 AM
Hill2302
11-05-2010 09:22 PM
