Driver side door handle issues - pls helps
So I had an issue where my driver side door handle would not open the door when locked unless I pulled it just right and then the lock would open...so I thought it was a stretched cable...I bought a new one and just put it in and I still have the problem...any ideas what it might be? Is it the door lock solenoid? All the mechanical parts of the locking mechanism looked fine when I installed the new cable...pls help
good idea! I am getting so tired of messing with these handles, I am thinking of making a push-button interior door handle using door pop solenoids. I broke my LH handle the other night after taking care of what little slack was in the cable. Thats the last straw I think. Its time to open my front doors with a solenoid!
I had the same thoughts until I thought about this: Isnt there the same problem even with the stock locks? Doesnt there have to be power anyway to unlock the door when the handle is pulled?
My door didnt even think about unlocking until I pulled the interior handle first to unlock the door. If it doesnt unlock, all the pulling in the world wont open it. I shimmed the cable, which is in another thread I posted and it gave me reliable door openings, but at dinner the other night I broke the handle. I wish these things would unlock manually when the handle is pulled, like a Ford. It seems to me that it unlocks electronically every time though. Thanks in advance.
You've obviously lived with a stretched cable, and instead of changing the part, you shimmed it, more stretch and wear, it broke. Now go get the cable ordered!
ixj8it (02-14-2012)
Thanks for the info on the locks. Now that you mention it, pulling up the LH one manually will unlock the rest, IIRC. I think you may be right on the cable, but I also dont want to end up like the OP. I think my LH latch is hard to pop or something. It requires much more effort from the outside (and apparently inside) to open than the right side does. I did some adjusting on the outside handle rod and it seemed to improve slightly when entering from the outside. If the cable was stretched (and shimmed), why did my handle still break at the pivot point even though it wasnt maxed out? I suspect the latch is too hard to actuate. I tried actuating the latch from the inside by hand and it was near impossible. I didnt succeed.
In the past I have always squirted into the opening where the latch meets the door jamb striker. This time I am going to do that and get it from as many angles as possible from inside. If its not too difficult, I may even remove the thing and give it a thorough inspection/lubing. I am going to use silicone lubricant or white lithium grease. If there are any especially dirty parts, I will clean the area with carb cleaner then slather it in lubricant. These doors have been the most annoying thing about this car. It has been just awesome otherwise.
NinoGrimace
08-26-2015 05:15 AM
